Traxxas Speed Controls and Low Voltage Detection (LVD)
Article #76606
Over-discharging a LiPo battery will cause irreparable damage and may cause battery failure. To prevent over-discharging, only use Traxxas Power Cell LiPo batteries with an electronic speed control (ESC) that has a low-voltage detection system or alarm.
All current Traxxas vehicles equipped with the XL-5 (w/LVD)EVX-2 (w/LVD), VXL-6s, VXL-3s, and VXL-3m have Low Voltage Detection (LVD). Older versions of the XL-5 and EVX-2 speed controls do not have Low Voltage Detection; see below to determine if you have the latest XL-5 or EVX-2 speed control.
The Traxxas E-Revo Brushless EditionE-Maxx Brushless EditionFunny Car, and XO-1 are equipped with Castle Creations speed controls that do have Low Voltage Detection.
How to Tell if Low Voltage Detection is ON
Traxxas ESCs will show a green light to indicate Low Voltage Detection is turned on; the Castle Creations ESC will beep once for each LiPo cell it detects (for example, 4 beeps if you have installed two 2-cell LiPo packs in your model). The Castle speed control automatically activates its low-voltage detection mode when it detects it is connected to LiPo batteries. If you are uncertain about how to turn on and use Low Voltage Detection, consult your vehicle's manual or call 888-TRAXXAS. We're happy to help.
If the LED glows GREEN when the ESC is on, Low Voltage Detection is activated
How to Turn Low Voltage Detection ON
If your Traxxas speed control with Low Voltage Detection displays a red light when switched on, it means that Low Voltage Detection is switched OFF. To turn it ON, first turn on your transmitter and speed control. With the speed control already on, press and hold the EZ-Set button until you hear an ascending tone (if you have a VXL speed control) or two beeps (if you have an XL-5 speed control). Release the EZ-Set button and the speed control's LED will light green to show Low Voltage Detection is ON. If it does not light green, do not operate your model with a LiPO battery. Repeat the procedure. Call 888-TRAXXAS if you cannot activate Low Voltage Detection.
If the LED glows RED when the ESC is on, Low Voltage Detection is DEACTIVATED.
To turn Low Voltage Detection on, press and hold the EZ-Set button until you hear an
ascending tone (VXL speed controls) or two beeps (XL-5 speed control).
Traxxas Speed Controls WITH Low Voltage Detection
XL-5 with BLACK background behind the Traxxas logo and "Low Voltage Detection"
in small print on the front of the speed control, beneath the EZ-Set button.
EVX-2
with "Low Voltage Detection" printed on the top of the speed control above the EZ-Set button.
VXL-6s
VXL-3s
VXL-3m
Traxxas Speed Controls That DO NOT Have Low Voltage Detection
The following Traxxas speed controls do NOT have Low Voltage Detection.
Do not use Power Cell LiPO batteries with these speed controls:
XL-1
XL-2.5
XL-5 with blue or yellow housing and WHITE background behind the Traxxas logo
XL-10 with blue or yellow housing and WHITE background behind the Traxxas logo
EVX-2
EVX-2 Marine
Nautica
5
Your rating: None Average: 5 (6 votes)
